This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! W670SZQ1 Keyboard Replacement
    1. why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 3 of 3
      • Unlock the lock latch on the left.
      • Unlock the lock latch on the right.
      • Remove the battery while holding the lock latch unlocked.
      Ask FixBot
    1. why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
      • Lift the bottom right cover with the iFixit Opening Tool.
      • Lift the lower left cover with the iFixit Opening Tool.
      • Finally clear the bottom cover completely to access the main components.
      Ask FixBot
    1. why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 1 of 3 why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 2 of 3 why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 3 of 3
      • Once the bottom cover is removed you can start disassembling the keyboard.
      • Start by turning the computer over and then unscrew the screw shown in image 2 of this step.
      • Then using the screwdriver unscrew the bar that hides the screws fixing the keyboard.
      Ask FixBot
    2. why! W670SZQ1 Keyboard Replacement: step 4, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 4, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 4, image 3 of 3
      • Once the bar hiding the fixing screws of the keyboard is unclipped we see the tip of the screwdriver.
      • Now find the 5 screws fixing the keyboard.
      • Unscrew the 5 screws.
      Ask FixBot
    3. why! W670SZQ1 Keyboard Replacement: step 5, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 5, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 5, image 3 of 3
      • Now gently lift the keyboard.
      • Then appear the keyboard connection cable and the keyboard backlight cable
      • Start by unlocking the right latch of the connector securing the backlight cable.
      Ask FixBot
    4. why! W670SZQ1 Keyboard Replacement: step 6, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 6, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 6, image 3 of 3
      • Then the one on the left.
      • Do the same with the left latch of the connector securing the main cable.
      • Then with the right latch of the connector fixing the main cable.
      Ask FixBot
    5. why! W670SZQ1 Keyboard Replacement: step 7, image 1 of 1
      • Then remove the keyboard from its location.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 105
All Time: 668
