why! W650SZ WiFi/Bluetooth Card Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. why! W650SZ WiFi/Bluetooth Card Replacement, la batterie: step 1, image 1 of 3 why! W650SZ WiFi/Bluetooth Card Replacement, la batterie: step 1, image 2 of 3 why! W650SZ WiFi/Bluetooth Card Replacement, la batterie: step 1, image 3 of 3
    • Déverrouiller le loquet de fixation de la batterie.
    • Déverrouiller le verrou de fixation de la batterie situé à gauche.
    • Retirer le bloc accumulateur de son logement.
    Ask FixBot
  2. why! W650SZ WiFi/Bluetooth Card Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 1 of 3 why! W650SZ WiFi/Bluetooth Card Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 2 of 3 why! W650SZ WiFi/Bluetooth Card Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 3 of 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
    Ask FixBot
  3. why! W650SZ WiFi/Bluetooth Card Replacement, Remove the WiFi/Bluetooth Card: step 3, image 1 of 1
    • Carefully unplug the MAIN and AUX antennas.
    • Remove the retaining screw with a Phillips #0 screwdriver.
    • Lift the chipset card and remove it from the mSATA connector.
    Ask FixBot
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,589 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 442
