This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the webcam in a why! V540TU laptop.
Unscrew the screws circled in red.
Insert the opening pick into the gap and slide it all the way around.
Unplug the cable connected to the motherboard.
Remove the adhesives.
Unscrew the screws circled in green.
Remove the adhesive.
Reinstall the clutch hinge.
Unplug the cable.
Insert the opening pick into the gap in the frame and slide it along the entire length.
Unclip the top of the frame, being careful of the adhesive.
Unclip one side of the frame, being careful of the adhesive.
Unclip the other side of the frame, being careful of the adhesive.
Unclip the bottom of the frame, being careful of the adhesive.
Remove the frame.
Pull the adhesive on one of the sides of the screen. Be careful not to break it.
Pull the adhesive from the other side of the screen. Be careful not to break it.
Unclip the connector without removing it.
Detach the webcam.
Remove the connector and take out the webcam.
To reassemble your device, follow the instructions in reverse order.
