This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! V540TU Upper Case Replacement
    1. why! V540TU Upper Case Replacement, Lower housing 1: step 1, image 1 of 3 why! V540TU Upper Case Replacement, Lower housing 1: step 1, image 2 of 3 why! V540TU Upper Case Replacement, Lower housing 1: step 1, image 3 of 3
      • Unscrew the screws circled in red.
      • Insert the opening pick into the gap and slide it all the way around.
      Ask FixBot
    2. why! V540TU Upper Case Replacement, Lower housing 2: step 2, image 1 of 3 why! V540TU Upper Case Replacement, Lower housing 2: step 2, image 2 of 3 why! V540TU Upper Case Replacement, Lower housing 2: step 2, image 3 of 3
      • Unclip the housing at the corners.
      • Lift the cover.
      Ask FixBot
    1. why! V540TU Upper Case Replacement, Battery cable: step 3, image 1 of 1
      • Unplug the cable.
      Ask FixBot
    1. why! V540TU Upper Case Replacement, Heatsink 1: step 4, image 1 of 3 why! V540TU Upper Case Replacement, Heatsink 1: step 4, image 2 of 3 why! V540TU Upper Case Replacement, Heatsink 1: step 4, image 3 of 3
      • Remove the adhesive from the first cable.
      • Remove the cable.
      Ask FixBot
    2. why! V540TU Upper Case Replacement, Heat Sink 2: step 5, image 1 of 3 why! V540TU Upper Case Replacement, Heat Sink 2: step 5, image 2 of 3 why! V540TU Upper Case Replacement, Heat Sink 2: step 5, image 3 of 3
      • Remove the second adhesive.
      • Remove the second cable.
      • Lift the heat sink.
      Ask FixBot
    1. why! V540TU Upper Case Replacement, Screen separation 1: step 6, image 1 of 2 why! V540TU Upper Case Replacement, Screen separation 1: step 6, image 2 of 2
      • Unplug the cable connected to the motherboard.
      • Remove the adhesives.
      • Unscrew the screws circled in green.
      Ask FixBot
    2. why! V540TU Upper Case Replacement, Screen separation 2: step 7, image 1 of 2 why! V540TU Upper Case Replacement, Screen separation 2: step 7, image 2 of 2
      • Lift the clutch hinge.
      • Remove the cable.
      Ask FixBot
    3. why! V540TU Upper Case Replacement, Screen separation 3: step 8, image 1 of 2 why! V540TU Upper Case Replacement, Screen separation 3: step 8, image 2 of 2
      • Remove the adhesive.
      • Reinstall the clutch hinge.
      • Unplug the cable.
      Ask FixBot
    4. why! V540TU Upper Case Replacement, Screen separation 4: step 9, image 1 of 1
      • Release the screen from the lower assembly.
      Ask FixBot
    1. why! V540TU Upper Case Replacement, Upper Frame 1: step 10, image 1 of 3 why! V540TU Upper Case Replacement, Upper Frame 1: step 10, image 2 of 3 why! V540TU Upper Case Replacement, Upper Frame 1: step 10, image 3 of 3
      • Insert the opening pick into the gap in the frame and slide it along the entire length.
      • Unclip the top of the frame, being careful of the adhesive.
      • Unclip one side of the frame, being careful of the adhesive.
      Ask FixBot
    2. why! V540TU Upper Case Replacement, Upper Frame 2: step 11, image 1 of 3 why! V540TU Upper Case Replacement, Upper Frame 2: step 11, image 2 of 3 why! V540TU Upper Case Replacement, Upper Frame 2: step 11, image 3 of 3
      • Unclip the other side of the frame, being careful of the adhesive.
      • Unclip the bottom of the frame, being careful of the adhesive.
      • Remove the frame.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 54
All Time: 186
