This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the USB board in a why! V540TU laptop.
Unscrew the screws circled in red.
Insert the opening pick into the gap and slide it all the way around.
Remove the adhesive from the first cable.
Remove the cable.
Remove the second adhesive.
Remove the second cable.
Lift the heat sink.
Gently lift the board and flip it over.
Unclip and remove the connector.
To reassemble your device, follow the instructions in reverse order.
