This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the power board of a why! V540TU laptop.
Unscrew the screws circled in red.
Insert the opening pick into the gap and slide it all the way around.
Insert the opening pick as shown and unclip the keyboard by sliding it along the entire length.
Do the same for both sides.
Gently lift the keyboard.
Unclip and remove the connectors circled in red in the direction of the arrow.
Remove the keyboard.
Remove the adhesive.
Unscrew the screw circled in red.
Remove the Wi-Fi card.
Remove the adhesive from the first cable.
Remove the cable.
Remove the second adhesive.
Remove the second cable.
Lift the heat sink.
Unplug the cable connected to the motherboard.
Remove the adhesives.
Unscrew the screws circled in green.
Reinstall the clutch hinge.
Unplug the cable.
Rotate the device and place it in the position shown in the image.
Unclip the two connectors circled in red.
Flip the device over and unscrew the screws circled in red.
Remove the motherboard.
Lift the board and carefully turn it over.
Unclip the connector, pull it out, and remove the board.
To reassemble your device, follow the instructions in reverse order.
