This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! V540TU Motherboard Replacement
    1. why! V540TU Motherboard Replacement, Lower housing 1: step 1, image 1 of 3 why! V540TU Motherboard Replacement, Lower housing 1: step 1, image 2 of 3 why! V540TU Motherboard Replacement, Lower housing 1: step 1, image 3 of 3
      • Unscrew the screws circled in red.
      • Insert the opening pick into the gap and slide it all the way around.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Lower housing 2: step 2, image 1 of 3 why! V540TU Motherboard Replacement, Lower housing 2: step 2, image 2 of 3 why! V540TU Motherboard Replacement, Lower housing 2: step 2, image 3 of 3
      • Unclip the housing at the corners.
      • Lift the cover.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Battery cable: step 3, image 1 of 1
      • Unplug the cable.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Battery 1: step 4, image 1 of 1
      • Unscrew the screws circled in red and remove the battery.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Keyboard 1: step 5, image 1 of 3 why! V540TU Motherboard Replacement, Keyboard 1: step 5, image 2 of 3 why! V540TU Motherboard Replacement, Keyboard 1: step 5, image 3 of 3
      • Insert the opening pick as shown and unclip the keyboard by sliding it along the entire length.
      • Do the same for both sides.
      • Gently lift the keyboard.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Keyboard 2: step 6, image 1 of 2 why! V540TU Motherboard Replacement, Keyboard 2: step 6, image 2 of 2
      • Unclip and remove the connectors circled in red in the direction of the arrow.
      • Remove the keyboard.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, SSD: step 7, image 1 of 3 why! V540TU Motherboard Replacement, SSD: step 7, image 2 of 3 why! V540TU Motherboard Replacement, SSD: step 7, image 3 of 3
      • Unscrew the screw.
      • Lift the SSD and remove it.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Left Speaker 1: step 8, image 1 of 3 why! V540TU Motherboard Replacement, Left Speaker 1: step 8, image 2 of 3 why! V540TU Motherboard Replacement, Left Speaker 1: step 8, image 3 of 3
      • Disconnect the cable.
      • Remove the adhesive.
      • Remove the speaker.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Right speaker: step 9, image 1 of 2 why! V540TU Motherboard Replacement, Right speaker: step 9, image 2 of 2
      • Unplug the cable.
      • Take out the speaker.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, BIOS Battery: step 10, image 1 of 2 why! V540TU Motherboard Replacement, BIOS Battery: step 10, image 2 of 2
      • Unplug the cable.
      • Peel off the battery.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, RAM: step 11, image 1 of 3 why! V540TU Motherboard Replacement, RAM: step 11, image 2 of 3 why! V540TU Motherboard Replacement, RAM: step 11, image 3 of 3
      • Spread the two metal arms apart.
      • Remove the RAM.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Wi-Fi 1: step 12, image 1 of 3 why! V540TU Motherboard Replacement, Wi-Fi 1: step 12, image 2 of 3 why! V540TU Motherboard Replacement, Wi-Fi 1: step 12, image 3 of 3
      • Unscrew the screw circled in red.
      • Remove the Wi-Fi card.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Wifi 2: step 13, image 1 of 2 why! V540TU Motherboard Replacement, Wifi 2: step 13, image 2 of 2
      • Unclip the cables.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Heatsink 1: step 14, image 1 of 3 why! V540TU Motherboard Replacement, Heatsink 1: step 14, image 2 of 3 why! V540TU Motherboard Replacement, Heatsink 1: step 14, image 3 of 3
      • Remove the adhesive from the first cable.
      • Remove the cable.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Heat Sink 2: step 15, image 1 of 3 why! V540TU Motherboard Replacement, Heat Sink 2: step 15, image 2 of 3 why! V540TU Motherboard Replacement, Heat Sink 2: step 15, image 3 of 3
      • Remove the second adhesive.
      • Remove the second cable.
      • Lift the heat sink.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Screen separation 1: step 16, image 1 of 2 why! V540TU Motherboard Replacement, Screen separation 1: step 16, image 2 of 2
      • Unplug the cable connected to the motherboard.
      • Remove the adhesives.
      • Unscrew the screws circled in green.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Screen separation 2: step 17, image 1 of 2 why! V540TU Motherboard Replacement, Screen separation 2: step 17, image 2 of 2
      • Lift the clutch hinge.
      • Remove the cable.
      Ask FixBot
    3. why! V540TU Motherboard Replacement, Screen separation 3: step 18, image 1 of 2 why! V540TU Motherboard Replacement, Screen separation 3: step 18, image 2 of 2
      • Reinstall the clutch hinge.
      • Unplug the cable.
      Ask FixBot
    4. why! V540TU Motherboard Replacement, Screen separation 4: step 19, image 1 of 1
      • Release the screen from the lower assembly.
      Ask FixBot
    1. why! V540TU Motherboard Replacement, Motherboard 1: step 20, image 1 of 3 why! V540TU Motherboard Replacement, Motherboard 1: step 20, image 2 of 3 why! V540TU Motherboard Replacement, Motherboard 1: step 20, image 3 of 3
      • Unclip and remove the connectors circled in red.
      Ask FixBot
    2. why! V540TU Motherboard Replacement, Motherboard 2: step 21, image 1 of 3 why! V540TU Motherboard Replacement, Motherboard 2: step 21, image 2 of 3 why! V540TU Motherboard Replacement, Motherboard 2: step 21, image 3 of 3
      • Rotate the device and place it in the position shown in the image.
      • Unclip the two connectors circled in red.
      Ask FixBot
    3. why! V540TU Motherboard Replacement, Motherboard 3: step 22, image 1 of 2 why! V540TU Motherboard Replacement, Motherboard 3: step 22, image 2 of 2
      • Flip the device over and unscrew the screws circled in red.
      • Remove the motherboard.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 52
All Time: 199
