This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the CMOS battery in a why! NV41MZ laptop.
Remove the 14 screws securing the bottom case to the laptop.
Unclip the case by sliding a plastic spudger into the slots in the case.
Remove the bottom case.
Remove the Phillips screw securing the SSD.
The SSD board will pop up slightly once the screw is removed. Lift it to relieve any tension and pull it straight out.
To reassemble your device, follow the instructions in reverse order.
