This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! NS5xAU Screen Replacement
    1. why! NS5xAU Screen Replacement, Cover 1: step 1, image 1 of 3 why! NS5xAU Screen Replacement, Cover 1: step 1, image 2 of 3 why! NS5xAU Screen Replacement, Cover 1: step 1, image 3 of 3
      • Unscrew the screws circled in red.
      • Unscrew the screws circled in blue.
      • Insert the opening pick.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, Cover 2: step 2, image 1 of 2 why! NS5xAU Screen Replacement, Cover 2: step 2, image 2 of 2
      • Lift the cover.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Battery cable: step 3, image 1 of 2 why! NS5xAU Screen Replacement, Battery cable: step 3, image 2 of 2
      • Unplug the cable.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Heatsink 1: step 4, image 1 of 3 why! NS5xAU Screen Replacement, Heatsink 1: step 4, image 2 of 3 why! NS5xAU Screen Replacement, Heatsink 1: step 4, image 3 of 3
      • Peel off the adhesive strip.
      • Unscrew the 6 screws, following the numerical order.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, CPU Cooler 2: step 5, image 1 of 3 why! NS5xAU Screen Replacement, CPU Cooler 2: step 5, image 2 of 3 why! NS5xAU Screen Replacement, CPU Cooler 2: step 5, image 3 of 3
      • Finish unscrewing the screws.
      • Unplug the cable.
      Ask FixBot
    3. why! NS5xAU Screen Replacement, Heat Sink 3: step 6, image 1 of 2 why! NS5xAU Screen Replacement, Heat Sink 3: step 6, image 2 of 2
      • Remove the heat sink.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Separation 1: step 7, image 1 of 3 why! NS5xAU Screen Replacement, Separation 1: step 7, image 2 of 3 why! NS5xAU Screen Replacement, Separation 1: step 7, image 3 of 3
      • Unscrew the screws and disconnect the cables outlined in orange.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, Separation 2: step 8, image 1 of 3 why! NS5xAU Screen Replacement, Separation 2: step 8, image 2 of 3 why! NS5xAU Screen Replacement, Separation 2: step 8, image 3 of 3
      • Peel off the adhesive.
      Ask FixBot
    3. why! NS5xAU Screen Replacement, Separation 3: step 9, image 1 of 2 why! NS5xAU Screen Replacement, Separation 3: step 9, image 2 of 2
      • Lift the clutch hinges.
      • Remove the cables from the lower module.
      Ask FixBot
    4. why! NS5xAU Screen Replacement, Step 4: step 10, image 1 of 3 why! NS5xAU Screen Replacement, Step 4: step 10, image 2 of 3 why! NS5xAU Screen Replacement, Step 4: step 10, image 3 of 3
      • Lift the lower module to a 90° angle.
      • Release the lower module.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Frame 1: step 11, image 1 of 3 why! NS5xAU Screen Replacement, Frame 1: step 11, image 2 of 3 why! NS5xAU Screen Replacement, Frame 1: step 11, image 3 of 3
      • Insert the opening pick into the frame seam and slide it around the edge.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, Frame 2: step 12, image 1 of 3 why! NS5xAU Screen Replacement, Frame 2: step 12, image 2 of 3 why! NS5xAU Screen Replacement, Frame 2: step 12, image 3 of 3
      • Slide the opening pick from top to bottom.
      • Unclip the top of the frame.
      Ask FixBot
    3. why! NS5xAU Screen Replacement, Frame 3: step 13, image 1 of 3 why! NS5xAU Screen Replacement, Frame 3: step 13, image 2 of 3 why! NS5xAU Screen Replacement, Frame 3: step 13, image 3 of 3
      • Remove the frame.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Lower frame 1: step 14, image 1 of 2 why! NS5xAU Screen Replacement, Lower frame 1: step 14, image 2 of 2
      • Remove the covers.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, Lower Frame 2: step 15, image 1 of 2 why! NS5xAU Screen Replacement, Lower Frame 2: step 15, image 2 of 2
      • Unscrew the 7 screws.
      Ask FixBot
    3. why! NS5xAU Screen Replacement, Lower Case 3: step 16, image 1 of 3 why! NS5xAU Screen Replacement, Lower Case 3: step 16, image 2 of 3 why! NS5xAU Screen Replacement, Lower Case 3: step 16, image 3 of 3
      • Slide the opening pick along the lower case.
      • Unclip the lower case and remove it.
      Ask FixBot
    1. why! NS5xAU Screen Replacement, Screen 1: step 17, image 1 of 3 why! NS5xAU Screen Replacement, Screen 1: step 17, image 2 of 3 why! NS5xAU Screen Replacement, Screen 1: step 17, image 3 of 3
      • Use the hair dryer to soften the adhesive strips on the screen.
      • Do not stay in one spot for too long.
      Ask FixBot
    2. why! NS5xAU Screen Replacement, Screen 2: step 18, image 1 of 3 why! NS5xAU Screen Replacement, Screen 2: step 18, image 2 of 3 why! NS5xAU Screen Replacement, Screen 2: step 18, image 3 of 3
      • Insert the pick and gently slide it along the screen to separate it from the adhesive strips.
      • Repeat for all four sides.
      Ask FixBot
    3. why! NS5xAU Screen Replacement, Screen 3: step 19, image 1 of 2 why! NS5xAU Screen Replacement, Screen 3: step 19, image 2 of 2
      • Lift the screen.
      • Remove the adhesive and unplug the cable.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 51
All Time: 176
