This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! N650DU Motherboard
    1. why! N650DU Motherboard, The Batteries: step 1, image 1 of 3 why! N650DU Motherboard, The Batteries: step 1, image 2 of 3 why! N650DU Motherboard, The Batteries: step 1, image 3 of 3
      • Unlock the button without spring.
      • Slide the battery up while unlocking the button with spring.
      Ask FixBot
    1. why! N650DU Motherboard, Access to major components: step 2, image 1 of 3 why! N650DU Motherboard, Access to major components: step 2, image 2 of 3 why! N650DU Motherboard, Access to major components: step 2, image 3 of 3
      • Unscrew the two large screws circled in red.
      • Unscrew the two small screws circled in green.
      • Slide the plate down and lift it.
      Ask FixBot
    1. why! N650DU Motherboard, RAM memory: step 3, image 1 of 3 why! N650DU Motherboard, RAM memory: step 3, image 2 of 3 why! N650DU Motherboard, RAM memory: step 3, image 3 of 3
      • Spread the two arms holding the RAM stick.
      • Remove the RAM stick.
      Ask FixBot
    1. why! N650DU Motherboard, SSD disk: step 4, image 1 of 2 why! N650DU Motherboard, SSD disk: step 4, image 2 of 2
      • Unscrew the screw circled in red.
      • Remove the SSD.
      Ask FixBot
    1. why! N650DU Motherboard, Hard disk: step 5, image 1 of 3 why! N650DU Motherboard, Hard disk: step 5, image 2 of 3 why! N650DU Motherboard, Hard disk: step 5, image 3 of 3
      • Pull the black tab up.
      Ask FixBot
    1. why! N650DU Motherboard, CD / DVD RW drive: step 6, image 1 of 3 why! N650DU Motherboard, CD / DVD RW drive: step 6, image 2 of 3 why! N650DU Motherboard, CD / DVD RW drive: step 6, image 3 of 3
      • Push the drive to the location indicated by the green arrow.
      • Remove the drive from its location.
      Ask FixBot
    1. why! N650DU Motherboard, Carte WLAN: step 7, image 1 of 3 why! N650DU Motherboard, Carte WLAN: step 7, image 2 of 3 why! N650DU Motherboard, Carte WLAN: step 7, image 3 of 3
      • Disconnect the WLAN card in the direction of the red arrow.
      • Unhook the two connectors circled in green on the WLAN card.
      Ask FixBot
    1. why! N650DU Motherboard, Processor: step 8, image 1 of 3 why! N650DU Motherboard, Processor: step 8, image 2 of 3 why! N650DU Motherboard, Processor: step 8, image 3 of 3
      • Unscrew the four screws circled in red
      • Lift the radiator with the black label
      Ask FixBot
    2. why! N650DU Motherboard: step 9, image 1 of 3 why! N650DU Motherboard: step 9, image 2 of 3 why! N650DU Motherboard: step 9, image 3 of 3
      • Push the lever in the direction of the red arrow while pushing it in
      • Lift the lever in the direction of the green arrow
      • Do not touch the bottom of the processor and take it by the sides
      Ask FixBot
    1. why! N650DU Motherboard, The fan: step 10, image 1 of 3 why! N650DU Motherboard, The fan: step 10, image 2 of 3 why! N650DU Motherboard, The fan: step 10, image 3 of 3
      • Unscrew the two screws circled in red.
      • Disconnect the connector surrounded in green.
      • Remove the cooling fan by lifting the blue framed tab.
      Ask FixBot
    1. why! N650DU Motherboard, Pile BIOS: step 11, image 1 of 2 why! N650DU Motherboard, Pile BIOS: step 11, image 2 of 2
      • Remove the battery using a flathead screwdriver.
      Ask FixBot
    1. why! N650DU Motherboard, The keyboard: step 12, image 1 of 3 why! N650DU Motherboard, The keyboard: step 12, image 2 of 3 why! N650DU Motherboard, The keyboard: step 12, image 3 of 3
      • Unscrew the screws circled in red and green.
      • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click.
      • Lift the keyboard.
      Ask FixBot
    2. why! N650DU Motherboard: step 13, image 1 of 3 why! N650DU Motherboard: step 13, image 2 of 3 why! N650DU Motherboard: step 13, image 3 of 3
      • Remove the red circled connector.
      • Pull the white drawer that holds the connector circled in blue in the direction of the green arrow.
      • Remove the connector surrounded in blue.
      Ask FixBot
    1. why! N650DU Motherboard, Motherboard: step 14, image 1 of 3 why! N650DU Motherboard, Motherboard: step 14, image 2 of 3 why! N650DU Motherboard, Motherboard: step 14, image 3 of 3
      • Lift the two black flaps.
      • Remove the two connectors circled in red.
      Ask FixBot
    2. why! N650DU Motherboard: step 15, image 1 of 3 why! N650DU Motherboard: step 15, image 2 of 3 why! N650DU Motherboard: step 15, image 3 of 3
      • Remove the thirteen screws circled in red.
      • Remove the top cover.
      Ask FixBot
    3. why! N650DU Motherboard: step 16, image 1 of 3 why! N650DU Motherboard: step 16, image 2 of 3 why! N650DU Motherboard: step 16, image 3 of 3
      • Lift the blue flap that holds the connector circled in green.
      • Disconnect the connector circled in green.
      • Disconnect the connector circled in red.
      Ask FixBot
    4. why! N650DU Motherboard: step 17, image 1 of 3 why! N650DU Motherboard: step 17, image 2 of 3 why! N650DU Motherboard: step 17, image 3 of 3
      • Disconnect the two connectors located in the green zone.
      • Disconnect the connector surrounded in blue.
      • Disconnect the red circled connector.
      Ask FixBot
    5. why! N650DU Motherboard: step 18, image 1 of 3 why! N650DU Motherboard: step 18, image 2 of 3 why! N650DU Motherboard: step 18, image 3 of 3
      • Remove the Micro SD port cover that is circled in green if there is one.
      • Unscrew the three screws circled in red.
      • Carefully remove the motherboard.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 97
All Time: 1,098
