This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! N240BU Replacing the LCD screen
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
85
All Time:
831
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the LCD screen on a why! N240BU laptop, for example in the case of a cracked screen or a faulty one.
    1. why! N240BU Replacing the LCD screen, Battery: step 1, image 1 of 2 why! N240BU Replacing the LCD screen, Battery: step 1, image 2 of 2
      • Start by unlocking the right locking latch.
      • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
      Ask FixBot
    1. why! N240BU Replacing the LCD screen, Access to main components: step 2, image 1 of 2 why! N240BU Replacing the LCD screen, Access to main components: step 2, image 2 of 2
      • Begin by spotting the dummy memory card.
      • Then, remove it and put it on your workplan.
      Ask FixBot
    2. why! N240BU Replacing the LCD screen: step 3, image 1 of 3 why! N240BU Replacing the LCD screen: step 3, image 2 of 3 why! N240BU Replacing the LCD screen: step 3, image 3 of 3
      • Locate the 15 screws that hold the bottom cover of the device in place.
      • Unscrew them and place them on your work surface.
      • Then, un-clip the bottom cover, starting with the side shown in the third picture.
      Ask FixBot
    1. why! N240BU Replacing the LCD screen, LCD screen: step 4, image 1 of 3 why! N240BU Replacing the LCD screen, LCD screen: step 4, image 2 of 3 why! N240BU Replacing the LCD screen, LCD screen: step 4, image 3 of 3
      • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
      • Then locate the two connectors on the LCD screen.
      • Disconnect the first connector.
      Ask FixBot
    2. why! N240BU Replacing the LCD screen: step 5, image 1 of 3 why! N240BU Replacing the LCD screen: step 5, image 2 of 3 why! N240BU Replacing the LCD screen: step 5, image 3 of 3
      • Peel off the tape from the second connector.
      • Then disconnect the second connector.
      • Locate the SSD M.2 drive.
      Ask FixBot
    3. why! N240BU Replacing the LCD screen: step 6, image 1 of 3 why! N240BU Replacing the LCD screen: step 6, image 2 of 3 why! N240BU Replacing the LCD screen: step 6, image 3 of 3
      • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
      • Free Wi-Fi connection cables now
      • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
      Ask FixBot
    4. why! N240BU Replacing the LCD screen: step 7, image 1 of 3 why! N240BU Replacing the LCD screen: step 7, image 2 of 3 why! N240BU Replacing the LCD screen: step 7, image 3 of 3
      • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
      • Then lift the Laptop as shown in the second image of this step.
      • Unscrew the first screw.
      Ask FixBot
    5. why! N240BU Replacing the LCD screen: step 8, image 1 of 3 why! N240BU Replacing the LCD screen: step 8, image 2 of 3 why! N240BU Replacing the LCD screen: step 8, image 3 of 3
      • Then unscrew the second screw.
      • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
      • Then the fourth screw.
      Ask FixBot
    6. why! N240BU Replacing the LCD screen: step 9, image 1 of 3 why! N240BU Replacing the LCD screen: step 9, image 2 of 3 why! N240BU Replacing the LCD screen: step 9, image 3 of 3
      • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
      • On the screen near the hinge now locate the two caches screws on the left.
      • Then look for those on the right.
      Ask FixBot
    7. why! N240BU Replacing the LCD screen: step 10, image 1 of 3 why! N240BU Replacing the LCD screen: step 10, image 2 of 3 why! N240BU Replacing the LCD screen: step 10, image 3 of 3
      • Now remove the screw covers near the left hinge.
      • first on the right side of the hinge.
      • then on the left side.
      Ask FixBot
    8. why! N240BU Replacing the LCD screen: step 11, image 1 of 3 why! N240BU Replacing the LCD screen: step 11, image 2 of 3 why! N240BU Replacing the LCD screen: step 11, image 3 of 3
      • Repeat near the right hinge
      • .Now return to the hinge on the left side and unscrew the outer screw.
      Ask FixBot
    9. why! N240BU Replacing the LCD screen: step 12, image 1 of 3 why! N240BU Replacing the LCD screen: step 12, image 2 of 3 why! N240BU Replacing the LCD screen: step 12, image 3 of 3
      • Then unscrew the inner screw.
      • Repeat on the side of the right hinge.
      Ask FixBot
    10. why! N240BU Replacing the LCD screen: step 13, image 1 of 3 why! N240BU Replacing the LCD screen: step 13, image 2 of 3 why! N240BU Replacing the LCD screen: step 13, image 3 of 3
      • You can now gently unclip the screen cover.
      • Locate the left hinge screw cover.
      • Locate the right hinge screw cover.
      Ask FixBot
    11. why! N240BU Replacing the LCD screen: step 14, image 1 of 3 why! N240BU Replacing the LCD screen: step 14, image 2 of 3 why! N240BU Replacing the LCD screen: step 14, image 3 of 3
      • Gently remove the screw cover on the left hinge.
      • Also remove the screw cover on the right hinge.
      • Once the screw caps are removed you will see the fixing screws.
      Ask FixBot
    12. why! N240BU Replacing the LCD screen: step 15, image 1 of 3 why! N240BU Replacing the LCD screen: step 15, image 2 of 3 why! N240BU Replacing the LCD screen: step 15, image 3 of 3
      • Now unscrew the screw on the left hinge.
      • Then unscrew the screw on the right hinge.
      • Once this is done you can now remove the hinge cover (left).
      Ask FixBot
    13. why! N240BU Replacing the LCD screen: step 16, image 1 of 3 why! N240BU Replacing the LCD screen: step 16, image 2 of 3 why! N240BU Replacing the LCD screen: step 16, image 3 of 3
      • Left hinged cover removed.
      • Then remove the cover from the right hinge.
      • Right hinge cover removed.
      Ask FixBot
    14. why! N240BU Replacing the LCD screen: step 17, image 1 of 3 why! N240BU Replacing the LCD screen: step 17, image 2 of 3 why! N240BU Replacing the LCD screen: step 17, image 3 of 3
      • once these operations are done you see the LCD screen ready to be dismounted.
      • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
      • Two on the right.
      Ask FixBot
    15. why! N240BU Replacing the LCD screen: step 18, image 1 of 3 why! N240BU Replacing the LCD screen: step 18, image 2 of 3 why! N240BU Replacing the LCD screen: step 18, image 3 of 3
      • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
      • You will then see the connection cable of the screen.
      • Locate its connector.
      Ask FixBot
    16. why! N240BU Replacing the LCD screen: step 19, image 1 of 2 why! N240BU Replacing the LCD screen: step 19, image 2 of 2
      • Disconnect the cable.
      • And here you can now put it on your work plan.
      Ask FixBot
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 85
All Time: 831
