This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Use this guide to disconnect the internal components to access and replace the motherboard in a why! N240BU laptop.
Parts
Tools
Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Unscrew the circled screws in green and red
Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
Lift the keyboard
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Unscrew the screw circled in red.
Pull out the M.2 SSD in the direction of the red arrows.
Remove the screw circled in red.
Lift up the hard drive.
Remove the hard drive in the direction of the red arrows.
Disconnect the two connectors marked in green.
Remove the WLAN card.
Press down on the two brackets boxed in red.
Remove the RAM stick in the direction of the red arrows.
Press with a screwdriver in the red circled area to spread the base of the battery
Remove the battery by holding the screwdriver down
Remove the two screws circled in red.
Disconnect the connector boxed in green in the direction of the green arrow.
Remove the cooling fan by lifting it up.
Lift the retaining flap off of the connector boxed in red.
Disconnect the connector boxed in red.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
