why! N131WU/BU/ZU RAM Replacement
  1. why! N131WU/BU/ZU RAM Replacement, Remove the Screws: step 1, image 1 of 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
    Ask FixBot
  2. why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: step 2, image 1 of 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: step 2, image 2 of 3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: step 2, image 3 of 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
    Ask FixBot
  3. why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: step 3, image 1 of 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: step 3, image 2 of 3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: step 3, image 3 of 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
    Ask FixBot
  4. why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: step 4, image 1 of 2 why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: step 4, image 2 of 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
    Ask FixBot
  5. why! N131WU/BU/ZU RAM Replacement, RAM (Memory): step 5, image 1 of 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): step 5, image 2 of 3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): step 5, image 3 of 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
    Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,589 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 32
All Time: 709
