uAttend bn6000 Speaker Replacement
  1. uAttend bn6000 Speaker Replacement, Disassembly: step 1, image 1 of 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    Ask FixBot
  2. uAttend bn6000 Speaker Replacement: step 2, image 1 of 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
    Ask FixBot
  3. uAttend bn6000 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
    Ask FixBot
  4. uAttend bn6000 Speaker Replacement: step 4, image 1 of 2 uAttend bn6000 Speaker Replacement: step 4, image 2 of 2
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 389
