Up to 20% off select tools
uAttend bn6000 Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
98
All Time:
1,087
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The screen provides the digital display for the unit. It is vital for the function of the entire unit operation. This guide will show how to remove and replace the screen. Take care not to damage the screen upon removal.
    1. uAttend bn6000 Screen Replacement, Disassembly: step 1, image 1 of 1
      • Make sure to unplug the device before starting.
      • Flip the device over.
      • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
      Ask FixBot
    2. uAttend bn6000 Screen Replacement: step 2, image 1 of 1
      • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
      Ask FixBot
    1. uAttend bn6000 Screen Replacement, Screen: step 3, image 1 of 2 uAttend bn6000 Screen Replacement, Screen: step 3, image 2 of 2
      • Remove the four 10mm PH #2 screws from the screen assembly, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
      • Remove the screen assembly from the housing by pulling the screen up and away from the housing.
      Ask FixBot
    2. uAttend bn6000 Screen Replacement: step 4, image 1 of 3 uAttend bn6000 Screen Replacement: step 4, image 2 of 3 uAttend bn6000 Screen Replacement: step 4, image 3 of 3
      • Disconnect the ZIF connector, by using the plastic opening tool to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
      Ask FixBot
Author
with
abdullah sumait
437 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 98
All Time: 1,087
