Up to 20% off select tools
uAttend bn6000 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
97
All Time:
934
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 6 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The keyboard is a vital component to the function of the unit. This guide will show to remove and replace the keyboard. Take care not to damage the keyboard when removed.
    1. uAttend bn6000 Keyboard Replacement, Disassembly: step 1, image 1 of 1
      • Make sure to unplug the device before starting.
      • Flip the device over.
      • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
      Ask FixBot
    2. uAttend bn6000 Keyboard Replacement: step 2, image 1 of 1
      • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
      Ask FixBot
    1. uAttend bn6000 Keyboard Replacement, Keyboard: step 3, image 1 of 2 uAttend bn6000 Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Remove the five 7mm PH #1 screws from the back of the keypad, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
      Ask FixBot
    2. uAttend bn6000 Keyboard Replacement: step 4, image 1 of 1
      • Remove the bundled cable connector from the keyboard by pulling the cable away from the connector in the same direction as the individual wires are running.
      Ask FixBot
Author
with
Will Mastel
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 97
All Time: 934
