ring Indoor Cam Motherboard Replacement
  1. ring Indoor Cam Motherboard Replacement, Body: step 1, image 1 of 3 ring Indoor Cam Motherboard Replacement, Body: step 1, image 2 of 3 ring Indoor Cam Motherboard Replacement, Body: step 1, image 3 of 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
    Ask FixBot
  2. ring Indoor Cam Motherboard Replacement: step 2, image 1 of 2 ring Indoor Cam Motherboard Replacement: step 2, image 2 of 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
    Ask FixBot
  3. ring Indoor Cam Motherboard Replacement: step 3, image 1 of 2 ring Indoor Cam Motherboard Replacement: step 3, image 2 of 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
    Ask FixBot
  4. ring Indoor Cam Motherboard Replacement: step 4, image 1 of 3 ring Indoor Cam Motherboard Replacement: step 4, image 2 of 3 ring Indoor Cam Motherboard Replacement: step 4, image 3 of 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
    Ask FixBot
  5. ring Indoor Cam Motherboard Replacement, Motherboard: step 5, image 1 of 3 ring Indoor Cam Motherboard Replacement, Motherboard: step 5, image 2 of 3 ring Indoor Cam Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Gently remove the three white leads from their sockets on the top of the motherboard.
    Ask FixBot
  6. ring Indoor Cam Motherboard Replacement: step 6, image 1 of 2 ring Indoor Cam Motherboard Replacement: step 6, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
    Ask FixBot
  7. ring Indoor Cam Motherboard Replacement: step 7, image 1 of 3 ring Indoor Cam Motherboard Replacement: step 7, image 2 of 3 ring Indoor Cam Motherboard Replacement: step 7, image 3 of 3
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
    Ask FixBot
  8. ring Indoor Cam Motherboard Replacement: step 8, image 1 of 2 ring Indoor Cam Motherboard Replacement: step 8, image 2 of 2
    • Detach the black wire connecting the motherboard to the body of the camera.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 39
All Time: 668
