ring Indoor Cam Body Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
124
All Time:
2,285
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide provides a replacement walkthrough for the body of the ring Indoor Cam. This walkthrough is useful for opening the device for internal repairs or replacement of the camera base or body.
While prying the device, insert multiple iFixit opening picks into the creases to loosen the interlocking of the cam covers and prevent damaging your device.
Tools
    1. ring Indoor Cam Body Replacement, Body: step 1, image 1 of 3 ring Indoor Cam Body Replacement, Body: step 1, image 2 of 3 ring Indoor Cam Body Replacement, Body: step 1, image 3 of 3
      • Place the cam with the base facing towards you.
      • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
      • Remove the base from the rest of the camera.
      Ask FixBot
    2. ring Indoor Cam Body Replacement: step 2, image 1 of 2 ring Indoor Cam Body Replacement: step 2, image 2 of 2
      • Place the cam with the top facing toward you.
      • Insert the iFixit opening pick into the crease at the top of the camera.
      • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
      • Leave the pick in the crease.
      Ask FixBot
    3. ring Indoor Cam Body Replacement: step 3, image 1 of 2 ring Indoor Cam Body Replacement: step 3, image 2 of 2
      • Place the camera on its side where the horizontal crease is facing you.
      • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
      Ask FixBot
    4. ring Indoor Cam Body Replacement: step 4, image 1 of 3 ring Indoor Cam Body Replacement: step 4, image 2 of 3 ring Indoor Cam Body Replacement: step 4, image 3 of 3
      • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
      • You may hear a popping noise when you pry it open.
      Ask FixBot
1 Guide Comment
My question is, which of the 3 clips inside controls the microphone.
Pete Cummings - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 124
All Time: 2,285
