nikon s3700 LCD Display Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
74
All Time:
1,086
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Step by step guide for replacing your damaged LCD Display.
Tools
    1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 1 of 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 2 of 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: step 1, image 3 of 3
      • group screws according to color code.
      • Remove exterior screws
      Ask FixBot
    2. nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 1 of 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 2 of 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: step 2, image 3 of 3
      • Remove Rear casing.
      • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
      • Flip over rear buttons board to expose LCD ZIF clamp.
      • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
      • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
      • Remove the LCD.
      Ask FixBot
2 other people completed this guide.
Sales Cameraparts4you
3,492 Reputation
23 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 74
All Time: 1,086
