First ensure your laptop is turned off and check if you have the necessary tools
After remove the battery, you need to remove the black mylar that covers keyboard connector.
Under the I/O board there's a hole that you need to insert a tool and push the keyboard at the same time you pull the plastic as show in the picture. This plastic holds the keyboard.
There are more holders, but you just need to open one, the others will sag when you pull the keyboard smoothly
2 other people completed this guide.
2 Guide Comments
Are US and portueguese/latin keyboards interchangeable for this model?
Yes, 100% interchangeable.
