Up to 20% off select tools
iyashi footrest Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
564
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to tear down an iyashi footrest and replace the front plastic panels.
    1. iyashi footrest Disassembly, Footrest: step 1, image 1 of 3 iyashi footrest Disassembly, Footrest: step 1, image 2 of 3 iyashi footrest Disassembly, Footrest: step 1, image 3 of 3
      • remove the 4 screws on the top and the bottom of the plastic cover .
      • This half front panel will need to be removed by sliding it up and off . BE CAREFUL AS THIS PANEL IS EASY TO BREAK.
      Ask FixBot
    2. iyashi footrest Disassembly: step 2, image 1 of 2 iyashi footrest Disassembly: step 2, image 2 of 2
      • Remove the 4 screws .
      • Remove the 5 screws on each edge of back panel.
      Ask FixBot
    3. iyashi footrest Disassembly: step 3, image 1 of 3 iyashi footrest Disassembly: step 3, image 2 of 3 iyashi footrest Disassembly: step 3, image 3 of 3
      • remove the wire harness by unscrewing the zip tie . DO NOT CUT THIS ZIP TIE
      • separate this cable from the harness.
      • When removing the rest of the back cover you need to thread this wire through the marked opening .
      Ask FixBot
    4. iyashi footrest Disassembly: step 4, image 1 of 2 iyashi footrest Disassembly: step 4, image 2 of 2
      • Once back cover is remove this what you should see
      • Next lay footrest down and remove the 4 bolts marked.
      Ask FixBot
    5. iyashi footrest Disassembly: step 5, image 1 of 1
      • Remove all 10 screws.
      • From here remove the bottom panel completely and turn the footrest back in the upright position.
      Ask FixBot
    6. iyashi footrest Disassembly: step 6, image 1 of 2 iyashi footrest Disassembly: step 6, image 2 of 2
      • Remove the 4 bolts with their metal and rubber washers.
      • The top left bolt may be cover by the sensor. To move the sensor , remove the 2 screws marked.
      • Grab the support bar and Motor track . Lift UP until clear of the plastic plate. Alternatively you can grab and lift by using the axle pins .
      • DO NOT PULL THIS ASSEMBLY TOWARDS YOU WHILE LIFTING IT OUT. THIS WILL RESULT IN DAMAGE. ONLY LIFT UP.
      • You can't remove this assembly until bottom panel is removed first
      Ask FixBot
    7. iyashi footrest Disassembly: step 7, image 1 of 3 iyashi footrest Disassembly: step 7, image 2 of 3 iyashi footrest Disassembly: step 7, image 3 of 3
      • Remove all 8 screws .
      • This image is another iteration of the panel, if you see this panel remove the 8 screws marked
      • Fold leather piece down and remove the 4 screws.
      Ask FixBot
    8. iyashi footrest Disassembly: step 8, image 1 of 1
      • This what you should see after back panel is removed. Please lay footrest down again to proceed with next step.
      Ask FixBot
    9. iyashi footrest Disassembly: step 9, image 1 of 3 iyashi footrest Disassembly: step 9, image 2 of 3 iyashi footrest Disassembly: step 9, image 3 of 3
      • Remove the top 4 screws
      • Slide Axle piece up to remove. PLEASE NOTE ITS POSITION as this will need to be remember during reassembly.
      • Now remove the 4 bottom screws .
      Ask FixBot
    10. iyashi footrest Disassembly: step 10, image 1 of 2 iyashi footrest Disassembly: step 10, image 2 of 2
      • Unplug both heel switches , and roller assembly should come out with ease.
      Ask FixBot
    11. iyashi footrest Disassembly: step 11, image 1 of 2 iyashi footrest Disassembly: step 11, image 2 of 2
      • Remove all 15 screws from plastic assembly .
      • Photo doesn't show all 15 screws , but all screws are in the same line through the left , right and middle .
      • Once all screws are removed , Front panel will come off.
      Ask FixBot
Author
with
Nick
2,764 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 564
