ionvac SmartClean V2 Side Brush Motors Replacement
  1. ionvac SmartClean V2 Side Brush Motors Replacement, Shell (Top & Bottom): step 1, image 1 of 2 ionvac SmartClean V2 Side Brush Motors Replacement, Shell (Top & Bottom): step 1, image 2 of 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Side Brush Motors Replacement: step 2, image 1 of 3 ionvac SmartClean V2 Side Brush Motors Replacement: step 2, image 2 of 3 ionvac SmartClean V2 Side Brush Motors Replacement: step 2, image 3 of 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Side Brush Motors Replacement: step 3, image 1 of 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Side Brush Motors Replacement: step 4, image 1 of 2 ionvac SmartClean V2 Side Brush Motors Replacement: step 4, image 2 of 2
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Side Brush Motors Replacement, Side Brush Motors: step 5, image 1 of 1
    • Identify the 2 side brush motors that look like cylinders on the bottom shelf of your ionvac.
  6. ionvac SmartClean V2 Side Brush Motors Replacement: step 6, image 1 of 2 ionvac SmartClean V2 Side Brush Motors Replacement: step 6, image 2 of 2
    • Remove the 3 screws that attach the motor to the bottom shelf.
    • Lift the motor out of its slot.
  7. ionvac SmartClean V2 Side Brush Motors Replacement: step 7, image 1 of 1
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 65
All Time: 889
