Up to 20% off select tools
ionvac SmartClean V2 Power Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
58
All Time:
927
Comments: 6
6 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your ionvac SmartClean V2 fails to power on, or the power button is loose, stuck, or broken, it may be a sign that the button needs to be replaced. In order to complete this process, you must first disassemble the top shell that houses the button. This guide will show you how to remove the power button without causing any damage.
This is a quick and easy replacement, and you will need a Phillips #2 (PH2) screwdriver and a Jimmy tool (or another prying tool) to complete it. Remember to remove and reinstall all parts gently.
    1. ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): step 1, image 1 of 2 ionvac SmartClean V2 Power Button Replacement, Shell (Top & Bottom): step 1, image 2 of 2
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      Ask FixBot
    2. ionvac SmartClean V2 Power Button Replacement: step 2, image 1 of 3 ionvac SmartClean V2 Power Button Replacement: step 2, image 2 of 3 ionvac SmartClean V2 Power Button Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      Ask FixBot
    3. ionvac SmartClean V2 Power Button Replacement: step 3, image 1 of 1
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      Ask FixBot
    4. ionvac SmartClean V2 Power Button Replacement: step 4, image 1 of 2 ionvac SmartClean V2 Power Button Replacement: step 4, image 2 of 2
      • Lift the top shell off carefully.
      Ask FixBot
    1. ionvac SmartClean V2 Power Button Replacement, Power Button: step 5, image 1 of 1
      • Flip the frame upside down so that the inside faces upwards.
      • Locate the 2 screws connecting the power button to the frame.
      Ask FixBot
    2. ionvac SmartClean V2 Power Button Replacement: step 6, image 1 of 1
      • Unscrew the two screws connecting the power button to the top shell.
      Ask FixBot
    3. ionvac SmartClean V2 Power Button Replacement: step 7, image 1 of 1
      • Remove the power button from the shell.
      • Position the power button correctly when reinstalling. The power icon should face the ionvac logo and the house icon should face the front of the robot vacuum.
      Ask FixBot
Author
with
Ruth Mekonnen
794 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 58
All Time: 927
