ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
    1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): step 1, image 1 of 1
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Flip your ionvac upside down so the wheels are pointed upwards.
      Ask FixBot
    2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: step 2, image 1 of 2 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: step 2, image 2 of 2
      • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
      • If the wheel is stuck, you can use a spudger to pry the caster out.
      • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 465
