ionvac SmartClean V2 Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
108
All Time:
3,902
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you notice that your ionvac SmartClean V2 has a shorter runtime or decreased performance, it may be time to replace the batteries. This guide demonstrates how to remove the lithium-ion battery unit from the bottom of the robot vacuum.
This is a quick and simple repair, but handle all parts gently during removal and reinstallation. Before you begin, power off your ionvac SmartClean V2 and disconnect it from the charging dock.
Caution: If you notice the battery is puffy or smells strange, it may be swollen. Be careful when handling a swollen battery as it can be a fire risk. For more information on swollen batteries and what to do with them, take a look at the What to Do With a Swollen Battery guide.
Tools
    1. ionvac SmartClean V2 Battery Replacement, Battery: step 1, image 1 of 1
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. A magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
      Ask FixBot
    2. ionvac SmartClean V2 Battery Replacement: step 2, image 1 of 2 ionvac SmartClean V2 Battery Replacement: step 2, image 2 of 2
      • Remove the 2 screws that secure the battery door.
      • Lift the battery door to reveal the lithium ion battery.
      • If the battery cover is stuck, use a Jimmy or another prying tool to pry it off.
      Ask FixBot
    3. ionvac SmartClean V2 Battery Replacement: step 3, image 1 of 2 ionvac SmartClean V2 Battery Replacement: step 3, image 2 of 2
      • Disconnect the battery by squeezing down on the cream-colored tabs of the battery connectors and pulling them apart.
      • Caution: Be careful when removing the connector, as the part can break if too much force is used.
      • When reinstalling the battery, remember to place it in your ionvac with the white strip facing up. If the battery has two flaps, ensure the flaps are facing up before screwing in the battery door.
      Ask FixBot
Dylan
346 Reputation
3 Guides authored
2 Guide Comments
need instructions for installation of battery in TZUMI ion vac smart clean robo vac V4
Eileen Meyer - Reply Share
need instructions for installation of battery in TZUMI ionvac smart clean robovac V4
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 108
All Time: 3,902
