iView-776TPCII Wi-Fi Antenna Replacement
    1. iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: step 1, image 1 of 3 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: step 1, image 2 of 3 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      Ask FixBot
    2. iView-776TPCII Wi-Fi Antenna Replacement: step 2, image 1 of 2 iView-776TPCII Wi-Fi Antenna Replacement: step 2, image 2 of 2
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      Ask FixBot
    1. iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: step 3, image 1 of 2 iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: step 3, image 2 of 2
      • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
      Ask FixBot
    2. iView-776TPCII Wi-Fi Antenna Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wire free from its connection.
      Ask FixBot
Cory Gratzer
586 Reputation
5 Guides authored
IUPUI, Team 2-2, Baechle Fall 2015 Member of IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 17
All Time: 738
