Up to 20% off select tools
iView-776TPCII Rear Panel Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
89
All Time:
1,094
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Moderate
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to open your tablet in order to view/repair its inner parts! Also, if you have a cracked or broken rear panel this guide will aid you in its replacement. One must take extreme care when removing the rear panel from the device because impatient prying may cause your screen or rear panel to break.
    1. iView-776TPCII Rear Panel Replacement, Rear Panel: step 1, image 1 of 3 iView-776TPCII Rear Panel Replacement, Rear Panel: step 1, image 2 of 3 iView-776TPCII Rear Panel Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      Ask FixBot
    2. iView-776TPCII Rear Panel Replacement: step 2, image 1 of 2 iView-776TPCII Rear Panel Replacement: step 2, image 2 of 2
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      Ask FixBot
Author
with
Jonathan Fenimore
314 Reputation
1 Guide authored
IUPUI, Team 2-2, Baechle Fall 2015 Member of IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 89
All Time: 1,094
