iVIEW-754TPC Speaker Replacement
    1. iVIEW-754TPC Speaker Replacement, Rear Panel: step 1, image 1 of 3 iVIEW-754TPC Speaker Replacement, Rear Panel: step 1, image 2 of 3 iVIEW-754TPC Speaker Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Ask FixBot
    1. iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: step 2, image 1 of 3 iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: step 2, image 2 of 3 iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Desoldier wires from the mother board. Use soldier iron to disconnect wires from mother board. Use tweezers to pull wires as the iron is heating.
      • Remove yellow tape from the speakers and use tweezers to pull speaker out.
      Ask FixBot
Robert Clark
1,065 Reputation
7 Guides authored
USF Tampa, Team 5-4, Brown Winter 2015 Member of USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 480
