iVIEW-754TPC Logic Board Replacement
    1. iVIEW-754TPC Logic Board Replacement, Rear Panel: step 1, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Rear Panel: step 1, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Ask FixBot
    1. iVIEW-754TPC Logic Board Replacement, Remove Battery: step 2, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Remove Battery: step 2, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Remove Battery: step 2, image 3 of 3
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      Ask FixBot
    1. iVIEW-754TPC Logic Board Replacement, Camera Assembly: step 3, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Camera Assembly: step 3, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Camera Assembly: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      Ask FixBot
    2. iVIEW-754TPC Logic Board Replacement, Remove Camera: step 4, image 1 of 2 iVIEW-754TPC Logic Board Replacement, Remove Camera: step 4, image 2 of 2
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      Ask FixBot
    1. iVIEW-754TPC Logic Board Replacement, Logic Board: step 5, image 1 of 1
      • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
      Ask FixBot
    2. iVIEW-754TPC Logic Board Replacement, WIFI Antenna: step 6, image 1 of 2 iVIEW-754TPC Logic Board Replacement, WIFI Antenna: step 6, image 2 of 2
      Buy
      • Gently peel the WIFI Antenna up using a pair of tweezers.
      Ask FixBot
    3. iVIEW-754TPC Logic Board Replacement, Disconnect LCD: step 7, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: step 7, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: step 7, image 3 of 3
      • Use a spudger to lift the flap on top of the LCD ZIF socket.
      • Gently remove the ribbon cable from the socket using a tweezers.
      Ask FixBot
    4. iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: step 8, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: step 8, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: step 8, image 3 of 3
      • Use a spudger to lift the flap on top of the digitizer ZIF socket.
      • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
      Ask FixBot
    5. iVIEW-754TPC Logic Board Replacement, Remove Logic Board: step 9, image 1 of 3 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: step 9, image 2 of 3 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: step 9, image 3 of 3
      • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
      • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
      Ask FixBot
Robert Clark
1,065 Reputation
7 Guides authored
USF Tampa, Team 5-4, Brown Winter 2015 Member of USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 1,360
