Up to 20% off select tools
iVIEW-754TPC Camera Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
88
All Time:
814
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
  • Tweezers
Introduction
Go to step 1 ↓
Is your camera not functioning correctly? Use this guide to replace the camera module in your device.
    1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: step 1, image 1 of 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: step 1, image 2 of 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Ask FixBot
    1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: step 2, image 1 of 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: step 2, image 2 of 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      Ask FixBot
    2. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: step 3, image 1 of 2 iVIEW-754TPC Camera Assembly Replacement, Remove Camera: step 3, image 2 of 2
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      Ask FixBot
Author
with
Robert Clark
1,065 Reputation
7 Guides authored
USF Tampa, Team 5-4, Brown Winter 2015 Member of USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 88
All Time: 814
