Tools
Spudger4.9
Introduction
Go to step 1 ↓Is your device no longer holding a charge? Use this guide to replace a faulty or worn out battery.
Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
3 other people completed this guide.
