iRulu AX760 Motherboard Replacement
    1. iRulu AX760 Motherboard Replacement, Battery: step 1, image 1 of 3 iRulu AX760 Motherboard Replacement, Battery: step 1, image 2 of 3 iRulu AX760 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Use a plastic opening tool or metal spudger to free the rear cover.
      • Insert your spudger into the side of your tablet.
      • Crack open each edge and remove the cover.
      Ask FixBot
    2. iRulu AX760 Motherboard Replacement: step 2, image 1 of 1
      • Open your tablet.
      Ask FixBot
    3. iRulu AX760 Motherboard Replacement: step 3, image 1 of 1
      • Take your plastic flat head tool and insert it under the battery.
      • Lift the battery up.
      • Make sure to remove any tape from the battery.
      Ask FixBot
    4. iRulu AX760 Motherboard Replacement: step 4, image 1 of 2 iRulu AX760 Motherboard Replacement: step 4, image 2 of 2
      • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
      • Keep the wires of the battery taught.
      • The iron should only be pressed to the solder for 2-3 seconds max.
      • Be very carful, the soldering iron will be very hot!
      • Visit this link for information about soldering. How To Solder and Desolder Connections
      Ask FixBot
    5. iRulu AX760 Motherboard Replacement: step 5, image 1 of 1
      • Remove your old battery and replace it with the new battery.
      Ask FixBot
    1. iRulu AX760 Motherboard Replacement, Motherboard: step 6, image 1 of 2 iRulu AX760 Motherboard Replacement, Motherboard: step 6, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • There are two thin adhesive strips under the battery that run vertically along the left and right side.
      • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
      • Do not use metal tools, and do not bend or puncture the battery.
      Ask FixBot
    2. iRulu AX760 Motherboard Replacement: step 7, image 1 of 3 iRulu AX760 Motherboard Replacement: step 7, image 2 of 3 iRulu AX760 Motherboard Replacement: step 7, image 3 of 3
      • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
      • For information on soldering and desoldering, check this link.
      • You must desolder several sets of contacts before attempting to remove the motherboard.
      • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
      Ask FixBot
    3. iRulu AX760 Motherboard Replacement: step 8, image 1 of 2 iRulu AX760 Motherboard Replacement: step 8, image 2 of 2
      • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
      Ask FixBot
    4. iRulu AX760 Motherboard Replacement: step 9, image 1 of 2 iRulu AX760 Motherboard Replacement: step 9, image 2 of 2
      • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
      • You will not need a metal spudger in order to re-place the motherboard
      Ask FixBot
Adam Schubach
123 Reputation
1 Guide authored
IUPUI, Team S6-G4, Baechle Spring 2018 Member of IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 43
All Time: 760
