iRulu AX760 Camera Replacement
    1. iRulu AX760 Camera Replacement, Battery: step 1, image 1 of 3 iRulu AX760 Camera Replacement, Battery: step 1, image 2 of 3 iRulu AX760 Camera Replacement, Battery: step 1, image 3 of 3
      • Use a plastic opening tool or metal spudger to free the rear cover.
      • Insert your spudger into the side of your tablet.
      • Crack open each edge and remove the cover.
      Ask FixBot
    2. iRulu AX760 Camera Replacement: step 2, image 1 of 1
      • Open your tablet.
      Ask FixBot
    3. iRulu AX760 Camera Replacement: step 3, image 1 of 1
      • Take your plastic flat head tool and insert it under the battery.
      • Lift the battery up.
      • Make sure to remove any tape from the battery.
      Ask FixBot
    4. iRulu AX760 Camera Replacement: step 4, image 1 of 2 iRulu AX760 Camera Replacement: step 4, image 2 of 2
      • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
      • Keep the wires of the battery taught.
      • The iron should only be pressed to the solder for 2-3 seconds max.
      • Be very carful, the soldering iron will be very hot!
      • Visit this link for information about soldering. How To Solder and Desolder Connections
      Ask FixBot
    5. iRulu AX760 Camera Replacement: step 5, image 1 of 1
      • Remove your old battery and replace it with the new battery.
      Ask FixBot
    1. iRulu AX760 Camera Replacement, Camera: step 6, image 1 of 2 iRulu AX760 Camera Replacement, Camera: step 6, image 2 of 2
      • Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
      Ask FixBot
    2. iRulu AX760 Camera Replacement: step 7, image 1 of 1
      • Pull the digitizer ribbon cables straight out of their sockets.
      Ask FixBot
    3. iRulu AX760 Camera Replacement: step 8, image 1 of 1
      • Pull the camera out of the device.
      Ask FixBot
Jamison Kritz
245 Reputation
2 Guides authored
IUPUI, Team S6-G4, Baechle Spring 2018 Member of IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 337
