iRobot looj 120 Front Motor Replacement
      • To remove the auger simply pull it off
      • Then unscrew the four screws holding the plastic part in place
      • You can then pull that off revealing the piece that connects to the motor
      • The metal piece can now be replaced by inserting a new one
      Ask FixBot
    1. iRobot looj 120 Front Motor Replacement, Removing Exterior Screws: step 2, image 1 of 1
      • Remove the four exterior screws, and then the top plate.
      • Once the top plate is removed check the motors circuitry. Disconnect the motor and install the new motor.
      Ask FixBot
Joshua
631 Reputation
6 Guides authored
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Members
83 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 533
