iRobot Roomba i4 Plus Caster Wheel Replacement
    1. iRobot Roomba i4 Plus Caster Wheel Replacement, Caster Wheel: step 1, image 1 of 1
      • Flip the Roomba over to access the side brush.
      • Firmly grasp the side brush with your fingers.
      • Use a Phillips #1 screwdriver to remove the single 7 mm center screw securing the side brush.
      • Be sure the sidebrush is held steady, because it will spin and be unable to be unscrewed if not.
      • Pull straight up to disconnect the side brush.
      Ask FixBot
    2. iRobot Roomba i4 Plus Caster Wheel Replacement: step 2, image 1 of 3 iRobot Roomba i4 Plus Caster Wheel Replacement: step 2, image 2 of 3 iRobot Roomba i4 Plus Caster Wheel Replacement: step 2, image 3 of 3
      • Use a Phillips #1 screwdriver to loosen the five 7 mm captive screws holding the back plate together.
      • The screws will not be able to be fully removed from the Back Plate.
      • Gently grab the edges of the back plate with your fingers and pull upwards to remove.
      Ask FixBot
    3. iRobot Roomba i4 Plus Caster Wheel Replacement: step 3, image 1 of 2 iRobot Roomba i4 Plus Caster Wheel Replacement: step 3, image 2 of 2
      • Insert a spudger under the caster.
      • Gently pry the caster wheel straight up from its socket.
      • Remove the caster wheel.
      Ask FixBot
Jaden Cochran
100 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 33
All Time: 205
