iRobot Roomba S9 Plus Left Wheel Module Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
30
Past 30 Days:
129
All Time:
5,102
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your iRobot Roomba S9 Plus has trouble driving, one or more wheel modules may be at fault. Check out our troubleshooting guide for other possible causes. If your wheel modules are indeed in need of replacement, this guide will walk you through the left wheel module replacement.
Tools
    1. iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Bottom Cover: step 1, image 3 of 3
      • Press the plastic hook under the lid.
      • Lift the handle and remove the bin.
      Ask FixBot
    2. iRobot Roomba S9 Plus Left Wheel Module Replacement: step 2, image 1 of 1
      • Flip over the Roomba.
      • Loosen, but do not remove, the eight screws on the bottom using a Phillips #2 screwdriver.
      Ask FixBot
    3. iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement: step 3, image 3 of 3
      • Lift and remove the brush module.
      • Remove the bottom cover.
      Ask FixBot
    1. iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 1 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 2 of 3 iRobot Roomba S9 Plus Left Wheel Module Replacement, Left Wheel Module: step 4, image 3 of 3
      • Lift the clip sensor.
      • Press the latch on the inside of the left wheel module using your spudger, then lift and remove the module.
      Ask FixBot
Patrick Bartlett
372 Reputation
3 Guides authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 129
All Time: 5,102
