iRobot Roomba S9 Plus Battery Module Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
158
All Time:
8,425
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
When the iRobot Roomba S9 Plus does not turn on or dies quickly, the battery will need to be replaced. If your battery module requires replacement, this guide will help you with the process. Check out our troubleshooting guide for other possible causes.
Remember to throw away your broken battery by going to a local tech store or check online to find the proper way to dispose of it.
Tools
    1. iRobot Roomba S9 Plus Battery Module Replacement, Battery Module: step 1, image 1 of 1
      • Using a Phillips #2 screwdriver, loosen the four screws in the bottom cover of the vacuum.
      • The screws cannot be removed and should be loosened.
      Ask FixBot
    2. iRobot Roomba S9 Plus Battery Module Replacement: step 2, image 1 of 2 iRobot Roomba S9 Plus Battery Module Replacement: step 2, image 2 of 2
      • Lift up the bottom cover to reveal the battery module.
      Ask FixBot
    3. iRobot Roomba S9 Plus Battery Module Replacement: step 3, image 1 of 2 iRobot Roomba S9 Plus Battery Module Replacement: step 3, image 2 of 2
      • Remove the 11mm Phillips #2 screw next to the battery module.
      Ask FixBot
    4. iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 1 of 3 iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 2 of 3 iRobot Roomba S9 Plus Battery Module Replacement: step 4, image 3 of 3
      • Pull the pull tabs to release the battery.
      • If the battery isn't releasing, make sure to check the screw next to the battery.
      Ask FixBot
7 other people completed this guide.
Jason Chu
309 Reputation
1 Guide authored
Cal Poly, Team S18-G3, White Winter 2020 Member of Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 158
All Time: 8,425
