iRobot Roomba Edge-Sweeping Brush Replacement
  1. iRobot Roomba Edge-Sweeping Brush Replacement, Loosen the edge brush screw: step 1, image 1 of 1
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
    Ask FixBot
  2. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: step 2, image 1 of 2 iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: step 2, image 2 of 2
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
    Ask FixBot
Tobias Isakeit
133,447 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 141
All Time: 2,929
