iRobot Roomba Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
18
Past 7 Days:
64
Past 30 Days:
345
All Time:
10,287
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Roomba.
If your battery is swollen, take appropriate precautions.
Parts
Tools
    1. iRobot Roomba Battery Replacement, Loosen the edge brush screw: step 1, image 1 of 1
      • Make sure your Roomba is turned off and flip it over to access its underside.
      • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
      • This screw is a captive screw and therefore not removable.
      Ask FixBot
    2. iRobot Roomba Battery Replacement, Remove the edge brush: step 2, image 1 of 2 iRobot Roomba Battery Replacement, Remove the edge brush: step 2, image 2 of 2
      • Use your fingers to gather all three brush arms and grab them simultaneously.
      • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
      Ask FixBot
    1. iRobot Roomba Battery Replacement, Loosen the bottom screws: step 3, image 1 of 2 iRobot Roomba Battery Replacement, Loosen the bottom screws: step 3, image 2 of 2
      • Use a Phillips screwdriver to loosen the five captive screws that hold the bottom plate in place.
      • Those screws are captive screws and therefore not removable.
      Ask FixBot
    2. iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 1 of 3 iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 2 of 3 iRobot Roomba Battery Replacement, Remove the bottom plate: step 4, image 3 of 3
      • Grab the bottom plate with your hand and remove it by lifting it straight up to reveal the battery.
      Ask FixBot
    3. iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 1 of 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 2 of 3 iRobot Roomba Battery Replacement, Unlatch and remove the battery: step 5, image 3 of 3
      • Use your finger to bend the plastic clip and unlatch the battery.
      • Grab the battery with your hand and lift it straight up from inside its recess to remove it.
      Ask FixBot
3 other people completed this guide.
Tobias Isakeit
136,100 Reputation
189 Guides authored
1 Guide Comment
J'ai changé la batterie compatible avec mon roomba mdle. 785, ça fonctionnait bien, mais au moment de la recharge elle ne reconnaît plus la batterie
Que faire
Lemon' attitude - Reply Share
Past 24 Hours: 18
Past 7 Days: 64
Past 30 Days: 345
All Time: 10,287
