iRobot Roomba 980 Brush Module Replacement
    1. iRobot Roomba 980 Brush Module Replacement, Battery: step 1, image 1 of 1
      • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
      Ask FixBot
    2. iRobot Roomba 980 Brush Module Replacement: step 2, image 1 of 2 iRobot Roomba 980 Brush Module Replacement: step 2, image 2 of 2
      • Unscrew the back plate using a Phillips #1 screwdriver.
      • Carefully lift the panel up once the screws are removed.
      Ask FixBot
    3. iRobot Roomba 980 Brush Module Replacement: step 3, image 1 of 2 iRobot Roomba 980 Brush Module Replacement: step 3, image 2 of 2
      • With both hands, grab the two black tabs on each end of the battery.
      • Pull the tabs upwards to remove the battery.
      Ask FixBot
    1. iRobot Roomba 980 Brush Module Replacement, Brush Module: step 4, image 1 of 3 iRobot Roomba 980 Brush Module Replacement, Brush Module: step 4, image 2 of 3 iRobot Roomba 980 Brush Module Replacement, Brush Module: step 4, image 3 of 3
      • Press down on the button on the rear of the device.
      • Pull bin towards you to remove it.
      Ask FixBot
    2. iRobot Roomba 980 Brush Module Replacement: step 5, image 1 of 2 iRobot Roomba 980 Brush Module Replacement: step 5, image 2 of 2
      • Loosen the screw holding the side brush in place.
      • The screw is attached to the side brush and does not come out completely.
      • Lift the side brush.
      Ask FixBot
    3. iRobot Roomba 980 Brush Module Replacement: step 6, image 1 of 2 iRobot Roomba 980 Brush Module Replacement: step 6, image 2 of 2
      • Remove the (2) 11.5mm Phillips #1 screws holding down the bottom plate.
      • Carefully lift the bottom plate.
      Ask FixBot
    4. iRobot Roomba 980 Brush Module Replacement: step 7, image 1 of 1
      • Remove the (4) 15.8mm Phillips #1 gold screws around the brush module.
      Ask FixBot
    5. iRobot Roomba 980 Brush Module Replacement: step 8, image 1 of 2 iRobot Roomba 980 Brush Module Replacement: step 8, image 2 of 2
      • Lift the brush module carefully using both hands.
      Ask FixBot
3 other people completed this guide.
Ernesto Rodriguez Romero
1,040 Reputation
4 Guides authored
USF Tampa, Team S14-G2, Boczar Fall 2017 Member of USF Tampa, Team S14-G2, Boczar Fall 2017
USFT-BOCZAR-F17S14G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 63
All Time: 5,325
