iRobot Roomba 960 Filter Replacement
    1. iRobot Roomba 960 Filter Replacement, Filter: step 1, image 1 of 1
      • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
      Ask FixBot
    2. iRobot Roomba 960 Filter Replacement: step 2, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 2, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 2, image 3 of 3
      • Press the large button on the Roomba that is located closest to you.
      • Pull to remove the dust bin.
      Ask FixBot
    3. iRobot Roomba 960 Filter Replacement: step 3, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 3, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 3, image 3 of 3
      • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
      • Lift the red plastic cover to access the filter.
      Ask FixBot
    4. iRobot Roomba 960 Filter Replacement: step 4, image 1 of 3 iRobot Roomba 960 Filter Replacement: step 4, image 2 of 3 iRobot Roomba 960 Filter Replacement: step 4, image 3 of 3
      • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
      • Carefully remove the used filter.
      Ask FixBot
Vanessa Greyson
471 Reputation
3 Guides authored
USF Tampa, Team 16-3, Blackwell Spring 2017 Member of USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
4 Members
60 Guides authored
1 Guide Comment
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 2,619
