iRobot Roomba 891 Extractor Assembly Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
67
All Time:
996
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This easy guide show you the steps to remove and replace the extractor assembly on your roomba.
Parts
Tools
    1. iRobot Roomba 891 Extractor Assembly Replacement, Battery: step 1, image 1 of 2 iRobot Roomba 891 Extractor Assembly Replacement, Battery: step 1, image 2 of 2
      • Start by flipping your Roomba onto its back on a flat surface.
      • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
      Ask FixBot
    2. iRobot Roomba 891 Extractor Assembly Replacement: step 2, image 1 of 1
      • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
      • These captive screws are not intended to be removed from the cover.
      Ask FixBot
    3. iRobot Roomba 891 Extractor Assembly Replacement: step 3, image 1 of 3 iRobot Roomba 891 Extractor Assembly Replacement: step 3, image 2 of 3 iRobot Roomba 891 Extractor Assembly Replacement: step 3, image 3 of 3
      • Grasp the tabs on either side of the battery.
      • Remove the battery by pulling up on the tabs.
      • While you're here, check the battery contacts for corrosion or debris.
      Ask FixBot
    1. iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: step 4, image 1 of 2 iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: step 4, image 2 of 2
      • Remove the 7.5mm flat head #4 screw from center of the side brush.
      Ask FixBot
    2. iRobot Roomba 891 Extractor Assembly Replacement: step 5, image 1 of 1
      • Gently pull the side brush off of the motor hub.
      Ask FixBot
    1. iRobot Roomba 891 Extractor Assembly Replacement, Extractor Assembly: step 6, image 1 of 1
      • Remove the dustbin assembly from the Roomba.
      Ask FixBot
    2. iRobot Roomba 891 Extractor Assembly Replacement: step 7, image 1 of 3 iRobot Roomba 891 Extractor Assembly Replacement: step 7, image 2 of 3 iRobot Roomba 891 Extractor Assembly Replacement: step 7, image 3 of 3
      • Unscrew the 2 phillips #2 11mm screws from roomba.
      • These captive screws will remain in the bottom cover after being loosened.
      Ask FixBot
    3. iRobot Roomba 891 Extractor Assembly Replacement: step 8, image 1 of 2 iRobot Roomba 891 Extractor Assembly Replacement: step 8, image 2 of 2
      • Lift the yellow tabs and lift the red cover from the extractor assembly.
      Ask FixBot
    4. iRobot Roomba 891 Extractor Assembly Replacement: step 9, image 1 of 1
      • Remove the rollers from the assembly by lifting it out from right side.
      Ask FixBot
    5. iRobot Roomba 891 Extractor Assembly Replacement: step 10, image 1 of 2 iRobot Roomba 891 Extractor Assembly Replacement: step 10, image 2 of 2
      • Close the cover and remove the four 11mm Phillips #00 screws from the assembly.
      Ask FixBot
    6. iRobot Roomba 891 Extractor Assembly Replacement: step 11, image 1 of 1
      • Grasp the center of the assembly and remove from the roomba.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 67
All Time: 996
