iRobot Roomba 890 Side Brush Module Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
111
All Time:
1,800
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. iRobot Roomba 890 Side Brush Module Replacement, Side Brush Module: step 1, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement, Side Brush Module: step 1, image 2 of 2
      • Use a #2 Phillips screwdriver to remove the 7.7 mm screw securing the side brush head.
      • Remove the yellow brush head.
      Ask FixBot
    2. iRobot Roomba 890 Side Brush Module Replacement: step 2, image 1 of 1
      • Place the Roomba with its bottom facing toward you.
      • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
      • Remove the battery cover.
      Ask FixBot
    3. iRobot Roomba 890 Side Brush Module Replacement: step 3, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 3, image 2 of 2
      • Pull directly up on the grey pull tabs to remove the battery.
      Ask FixBot
    4. iRobot Roomba 890 Side Brush Module Replacement: step 4, image 1 of 1
      • Lift off the baseplate.
      Ask FixBot
    5. iRobot Roomba 890 Side Brush Module Replacement: step 5, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 5, image 2 of 2
      • Press the dustbin release button and pull it straight out.
      Ask FixBot
    6. iRobot Roomba 890 Side Brush Module Replacement: step 6, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 6, image 2 of 2
      • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the two 15.5 mm screws.
      Ask FixBot
    7. iRobot Roomba 890 Side Brush Module Replacement: step 7, image 1 of 2 iRobot Roomba 890 Side Brush Module Replacement: step 7, image 2 of 2
      • Grip the side brush module casing and lift it out vertically, perpendicular to the Roomba.
      Ask FixBot
Dustin Staples
339 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 111
All Time: 1,800
