iRobot Roomba 870 Battery Replacement
    1. iRobot Roomba 870 Battery Replacement, Battery: step 1, image 1 of 2 iRobot Roomba 870 Battery Replacement, Battery: step 1, image 2 of 2
      • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
      • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
      • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
      Ask FixBot
    2. iRobot Roomba 870 Battery Replacement: step 2, image 1 of 3 iRobot Roomba 870 Battery Replacement: step 2, image 2 of 3 iRobot Roomba 870 Battery Replacement: step 2, image 3 of 3
      • Remove the loose battery cover to access the battery compartment.
      • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
      Ask FixBot
Follow the steps in reverse order for reassembly.
2 other people completed this guide.
Vitek Harvey
149 Reputation
1 Guide authored
Cal Poly, Team S14-G3, Banghart Spring 2017 Member of Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 86
All Time: 4,149
