iRobot Roomba 870 Bumper Sensor Replacement
    1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: step 1, image 1 of 2 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: step 1, image 2 of 2
      • Flip the iRoomba over so that the underside is facing up.
      • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
      • Remove the yellow side brush.
      Ask FixBot
    2. iRobot Roomba 870  Bumper Sensor Replacement: step 2, image 1 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 2, image 2 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 2, image 3 of 3
      • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
      • Remove the battery cover.
      Ask FixBot
    3. iRobot Roomba 870  Bumper Sensor Replacement: step 3, image 1 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 3, image 2 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 3, image 3 of 3
      • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
      • Remove the entire base-plate from the bottom of the Roomba.
      Ask FixBot
    4. iRobot Roomba 870  Bumper Sensor Replacement: step 4, image 1 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 4, image 2 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 4, image 3 of 3
      • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
      • Remove the bumper guard.
      Ask FixBot
    5. iRobot Roomba 870  Bumper Sensor Replacement: step 5, image 1 of 2 iRobot Roomba 870  Bumper Sensor Replacement: step 5, image 2 of 2
      • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
      • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
      Ask FixBot
    6. iRobot Roomba 870  Bumper Sensor Replacement: step 6, image 1 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 6, image 2 of 3 iRobot Roomba 870  Bumper Sensor Replacement: step 6, image 3 of 3
      • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
      • Carefully detach the sensor connector from the bumper and the sensor.
      Ask FixBot
    7. iRobot Roomba 870  Bumper Sensor Replacement: step 7, image 1 of 2 iRobot Roomba 870  Bumper Sensor Replacement: step 7, image 2 of 2
      • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
      • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
      • Gently remove the bumper from the black infrared sensor.
      Ask FixBot
13 other people completed this guide.
Jacob Lindberg
449 Reputation
1 Guide authored
Cal Poly, Team S14-G3, Banghart Spring 2017 Member of Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Members
60 Guides authored
3 Guide Comments
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - Reply Share
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - Reply Share
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 38
All Time: 9,235
