iRobot Roomba 860 Battery Replacement
    1. iRobot Roomba 860 Battery Replacement, Battery: step 1, image 1 of 1
      • Start by powering down the device to remove the battery from the iRobot Roomba 860.
      Ask FixBot
    2. iRobot Roomba 860 Battery Replacement: step 2, image 1 of 2 iRobot Roomba 860 Battery Replacement: step 2, image 2 of 2
      • Flip the Roomba over so that the underside is facing up.
      • Locate the battery panel and the 2 - 7 mm Phillips #2 Point Screws.
      • Using a Phillips #2 Point Screwdriver, remove the screws and use your fingers to pull the cover away from the device.
      Ask FixBot
    3. iRobot Roomba 860 Battery Replacement: step 3, image 1 of 2 iRobot Roomba 860 Battery Replacement: step 3, image 2 of 2
      • Locate the two fabric tabs on the side of the battery.
      • Pull up on the tabs to easily remove the battery.
      Ask FixBot
Ryan Murphy
446 Reputation
4 Guides authored
USF Tampa, Team S13-G5, Cagle Spring 2017 Member of USF Tampa, Team S13-G5, Cagle Spring 2017
USFT-CAGLE-S17S13G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,511
