iRobot Roomba 805 Motor Replacement
    1. iRobot Roomba 805 Motor Replacement, Side brush: step 1, image 1 of 1
      • Remove the single 6.1mm Phillips #0 screw from the side brush.
      Ask FixBot
    2. iRobot Roomba 805 Motor Replacement: step 2, image 1 of 1
      • Lift the side brush, removing it from the motor.
      Ask FixBot
    1. iRobot Roomba 805 Motor Replacement, Motor: step 3, image 1 of 2 iRobot Roomba 805 Motor Replacement, Motor: step 3, image 2 of 2
      • Remove the battery panel and the two screws behind the wheels.
      • Lift up the back panel and remove it from the Roomba.
      Ask FixBot
    2. iRobot Roomba 805 Motor Replacement: step 4, image 1 of 1
      • Remove the three screws holding down the motor. Be aware one requires a tristar bit and the plastic piece under that screw comes free easily.
      • Once the motor is loose you can pull it up out of the Roomba.
      Ask FixBot
    3. iRobot Roomba 805 Motor Replacement: step 5, image 1 of 3 iRobot Roomba 805 Motor Replacement: step 5, image 2 of 3 iRobot Roomba 805 Motor Replacement: step 5, image 3 of 3
      • Hold the motor by the bottom and the edge of the cap and remove the cap.
      Ask FixBot
Grady Landers
635 Reputation
5 Guides authored
1 Guide Comment
What is the point of step 5??
overkillx7 - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 36
All Time: 1,436
