iRobot Roomba 770 Battery Replacement
    1. iRobot Roomba 770 Battery Replacement, Battery: step 1, image 1 of 2 iRobot Roomba 770 Battery Replacement, Battery: step 1, image 2 of 2
      • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
      • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
      • Remove the plastic plate from the battery box.
      Ask FixBot
    2. iRobot Roomba 770 Battery Replacement: step 2, image 1 of 2 iRobot Roomba 770 Battery Replacement: step 2, image 2 of 2
      • Locate the 2 green tabs on the left and right of the big yellow battery.
      • Grab the tabs with your hands and lift straight upward.
      Ask FixBot
4 other people completed this guide.
Andrew Horvath
486 Reputation
3 Guides authored
Cal Poly, Team 15-3, Livingston Fall 2016 Member of Cal Poly, Team 15-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 51
All Time: 4,702
