iRobot Roomba 692 Wheels Replacement
    1. iRobot Roomba 692 Wheels Replacement, Battery: step 1, image 1 of 3 iRobot Roomba 692 Wheels Replacement, Battery: step 1, image 2 of 3 iRobot Roomba 692 Wheels Replacement, Battery: step 1, image 3 of 3
      • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
      • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
      Ask FixBot
    2. iRobot Roomba 692 Wheels Replacement: step 2, image 1 of 3 iRobot Roomba 692 Wheels Replacement: step 2, image 2 of 3 iRobot Roomba 692 Wheels Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
      • Remove the bottom panel.
      • Can't find the screws? Refer to the red circles in the Step 1 image.
      Ask FixBot
    3. iRobot Roomba 692 Wheels Replacement: step 3, image 1 of 3 iRobot Roomba 692 Wheels Replacement: step 3, image 2 of 3 iRobot Roomba 692 Wheels Replacement: step 3, image 3 of 3
      • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
      Ask FixBot
    1. iRobot Roomba 692 Wheels Replacement, Wheels: step 4, image 1 of 3 iRobot Roomba 692 Wheels Replacement, Wheels: step 4, image 2 of 3 iRobot Roomba 692 Wheels Replacement, Wheels: step 4, image 3 of 3
      • Remove three gold 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
      • Remove the drive wheels from the vacuum.
      • Each drive wheel is labeled left and right.
      Ask FixBot
Demi Muyuela
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 940
