iRobot Roomba 692 Battery Replacement
    1. iRobot Roomba 692 Battery Replacement, Battery: step 1, image 1 of 3 iRobot Roomba 692 Battery Replacement, Battery: step 1, image 2 of 3 iRobot Roomba 692 Battery Replacement, Battery: step 1, image 3 of 3
      • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
      • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
      Ask FixBot
    2. iRobot Roomba 692 Battery Replacement: step 2, image 1 of 3 iRobot Roomba 692 Battery Replacement: step 2, image 2 of 3 iRobot Roomba 692 Battery Replacement: step 2, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
      • Remove the bottom panel.
      • Can't find the screws? Refer to the red circles in the Step 1 image.
      Ask FixBot
    3. iRobot Roomba 692 Battery Replacement: step 3, image 1 of 3 iRobot Roomba 692 Battery Replacement: step 3, image 2 of 3 iRobot Roomba 692 Battery Replacement: step 3, image 3 of 3
      • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
      Ask FixBot
Demi Muyuela
507 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 56
All Time: 1,869
